liquidmonkey
May 10, 2012Aspirant
NV+ v2 and WD TV Live
ok, i have a NV+ v2 with the lastest firmware and it has 2 WD green 2TB drives setup in a JBOD way. i have some shares setup, a few from the first drive (c:) and a few from the second drive (d:) bot...
May 15, 2012Guru - Experienced User
Just to clarify "MEDIA SERVERS" in WDTV-speak is "DLNA". So if you want to pursue that issue, you should probably follow up with the details of your DLNA configuration. I think there is also a DLNA update for the v2 posted here, you might search for that.
I've found that accessing the shares directly works better with most media players (when they support that mode), unless you need the DLNA server to transcode. So sticking with NETWORK SHARES might be best anyway.
