kalpsr
Nov 22, 2014Aspirant
NV+ V2 Volume C: RAID Level X2, Not redundant
Sir,
I am using a NV+ V2 with radiator version 5.3.9 and 4x2 tb Seagate hdds.
I changed the 4th Hdd with same model sometime ago as it was giving smart errors.
Today after booting up there was ticking sound from Hdd1, so i just hot-plugged and re-plugged it.
After that it is showing Volume C Unprotected.
Below are some entries from Log :
Please guide me further on this.
The paths for the shares listed below could not be found.
Typically, this occurs when the ReadyNAS is unable to access the data volume.
Share1
media
Share2
Share3
Sat Nov 22 12:33:34 IST 2014 Volume scan failed to run properly.
Sat Nov 22 12:00:44 IST 2014 System is up.
Sat Nov 22 11:59:29 IST 2014 Volume scan found no errors.
temp!!1!!status=ok::descr=38.2C/100.8F::expected=0-65C/32-149F
fan!!1!!status=ok::descr=1365RPM::type=SYS
ups!!1!!status=not_present::descr=Not present
volume!!1!!status=warn::descr=Volume C: RAID Level X2, Not redundant. A disk failure will render this volume dead.; 4260 GB (76%) of 5543 GB used
disk!!1!!status=ok::descr=Channel 1: ST2000DM001-9YN164 1863 GB, 39C/102F
disk!!2!!status=ok::descr=Channel 2: ST2000DM001-9YN164 1863 GB, 38C/100F
disk!!3!!status=ok::descr=Channel 3: ST2000DM001-9YN164 1863 GB, 39C/102F
disk!!4!!status=ok::descr=Channel 4: ST2000DM001-1CH164 1863 GB, 37C/98F
model!!0!!mode=home::descr=ReadyNAS NV+ v2::arch=arm1::jbod=1
- mdgm-ntgrNETGEAR Employee RetiredDo you have a backup?
- kalpsrAspirantNo sir. Currently its not possible to backup whole data.
- mdgm-ntgrNETGEAR Employee RetiredYou may wish to contact our support team.
We have some paid options for looking into situations like these to see what can be done.
If a disk is failing you shouldn't remove then re-insert it. You should remove it and get a new disk.
But, you should maintain regular backups of important data. Important data should never be stored on just the one device.
