cras's avatar
cras
NV+ v2 wrong capacity after expansion; 2TB instead of 3TB
Hello @all,
I have an ReadyNAS NV+ v2 with RAIDiator 5.3.7 and a Flex-Raid-Configuration with JBOD. I use a 3TB hard drive and 2x2TB hard drives.
I added another 3TB-HDD in Bay 4. After a few minutes of waiting, the NAS created a new volume. But only with 2TB instead of 3TB.
So I remove the hard drive and deleted the partitions and installed everything again.
Same result.
Please Help.
  • If possible, please give a remote access for checking.
  • Hello Rabbie,
    Sorry it is impossible to give a remote access, but you can get the logs. Please tell me what you need and where I can find it.
  • can you post "mdstat" and partitions log here?I am testing this issue in my lab.
  • couldn't replicate this issue,2*2TB+2*3TB created in JBOD mode without problem
  • Thank you for your test.
    Here are my configuration and the logs:
    Bay1: WD30EFRX (3TB)
    Bay2: WD20EARS (2TB)
    Bay3: WD20EARS (2TB)
    Bay4: WD30EFRX (3TB)
    I can't change the position of the HDDs in Bay 1 -3, because I don't have so much backup space at the moment ;)
    "mdstat":
    Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
    md5 : active raid0 sdd3[0]
    1948794912 blocks super 1.2 16k chunks
    md4 : active raid0 sdc3[0]
    md3 : active raid0 sdb3[0]
    md2 : active raid0 sda3[0]
    2925544832 blocks super 1.2 64k chunks
    md1 : active raid1 sda2[0] sdd2[4] sdc2[2] sdb2[1]
    524276 blocks super 1.2 [4/4] [UUUU]
    md0 : active raid1 sda1[0] sdd1[4] sdc1[2] sdb1[1]
    4193268 blocks super 1.2 [4/4] [UUUU]
    unused devices: <none>
    and here is the partions.log
    ***** Disk partition log from 2013/01/20 *****
    ***** Disk partition log for channel 1 [sda] *****
    Disk /dev/sda: 5860533168 sectors, 2.7 TiB
    Logical sector size: 512 bytes
    Disk identifier (GUID): 66FC21AB-FB5C-4EF6-93F7-F033431A09F9
    Partition table holds up to 128 entries
    First usable sector is 34, last usable sector is 5860533134
    Partitions will be aligned on 64-sector boundaries
    Total free space is 4092 sectors (2.0 MiB)
    Number Start (sector) End (sector) Size Code Name
    1 64 8388671 4.0 GiB FD00
    2 8388672 9437247 512.0 MiB FD00
    3 9437248 5860529072 2.7 TiB FD00
    # partition table of /dev/sda
    unit: sectors
    /dev/sda1 : start= 1, size=4294967295, Id=ee
    /dev/sda2 : start= 0, size= 0, Id= 0
    /dev/sda3 : start= 0, size= 0, Id= 0
    /dev/sda4 : start= 0, size= 0, Id= 0
    ***** Disk partition log for channel 2 [sdb] *****
    Disk /dev/sdb: 3907029168 sectors, 1.8 TiB
    Disk identifier (GUID): DD6C3DA2-A9DE-4D10-A897-68D01EEB8C6D
    First usable sector is 34, last usable sector is 3907029134
    Total free space is 30 sectors (15.0 KiB)
    3 9437248 3907029134 1.8 TiB FD00
    # partition table of /dev/sdb
    unit: sectors
    /dev/sdb1 : start= 1, size=3907029167, Id=ee
    /dev/sdb2 : start= 0, size= 0, Id= 0
    /dev/sdb3 : start= 0, size= 0, Id= 0
    /dev/sdb4 : start= 0, size= 0, Id= 0
    ***** Disk partition log for channel 3 [sdc] *****
    Disk /dev/sdc: 3907029168 sectors, 1.8 TiB
    Disk identifier (GUID): 5C6C8CBF-2185-4D84-9EDE-72E04C828870
    # partition table of /dev/sdc
    unit: sectors
    /dev/sdc1 : start= 1, size=3907029167, Id=ee
    /dev/sdc2 : start= 0, size= 0, Id= 0
    /dev/sdc3 : start= 0, size= 0, Id= 0
    /dev/sdc4 : start= 0, size= 0, Id= 0
  • I tested this issue again and adjusted hard drives' order,still haven't found problem
    2925546912 blocks super 1.2 16k chunks
    1948792832 blocks super 1.2 64k chunks
    md1 : active raid1 sdd2[3] sdc2[2] sdb2[1] sda2[0]
    md0 : active raid1 sdd1[3] sdc1[2] sdb1[1] sda1[0]
    So can you contact support center to take a look your device?
  • As the first, thank you for your help. I have now found the solution.
    My problem is a bug in the firmware. These always uses the smallest HDD as an reference for the capacity when a new disk is added in JBOD mode. This is regardless of drive bay. After I had backed up the data of the two 2TB HDDs and these were removed. The 3TB HDD is correct formatted with 3TB.
ProSupport for Business
