Rubatoguy
Dec 26, 2013Aspirant
NV+ will not boot - LED flashes
Hello, I have an NV+ with 4 2TB drives. The unit was not responding and the message on the front panel was "Spinning down..." but this remained on for over 20 minutes. I removed power and tried to res...
Dec 29, 2013Guru - Experienced User
WDC's lifeguard program shouldn't damage the drive. Windows won't recognize the format at all; as long as you are careful not to reformat with the Windows disk manager you should be ok. You can test with a USB adapter btw.
There is a memory diag built into the boot menu that you can use.
