Rubatoguy
Dec 26, 2013Aspirant
NV+ will not boot - LED flashes
Hello, I have an NV+ with 4 2TB drives. The unit was not responding and the message on the front panel was "Spinning down..." but this remained on for over 20 minutes. I removed power and tried to res...
Dec 30, 2013Guru - Experienced User
There aren't any instructions. If you connect the drives with a sata/usb adapter (also power) Lifeguard will find/test them. eSATA or SATA is probably better, but is often not possible. The adaptors are widely available, and in the US cost about $25 on-line. You can also use a USB enclosure.
You can't bring up the boot menu if you press and hold the power button?
