Condor101
Sep 23, 2015Aspirant
NV+ will not boot - LED flashes
Hi All, Does anyone know what the following LED state means: Green LED against drive 1 blinks 5 times. Then all 5 green LEDs (drive 1 to 4 and act) and the blue power button blinks 3 times qu...
- Sep 23, 2015
Also have a read through this. The led pattern is similar.
https://community.netgear.com/t5/Using-your-ReadyNAS/NV-will-not-boot-LED-flashes/td-p/925981
Although the led pattern is not typical of a memory problem, the user in that post made progress by changing the memory. Worth trying to do a memory test too if the unit lets you.
Factory default:
vandermerwe
Sep 23, 2015Master
That pattern doesn't match any of the led code guides I have.
Do you have a NV + v1 - your older posts don't confirm what model you have?
Use this guide:
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
When did you buy it?
Do you have a backup?
You seem to have tried quite a few things but you don't mention trying to factory default the nas with a single, known good, drive in the nas.
What usb boot recovery image did you use for the USB boot recovery and what instructions did you follow? Did you do it with a disk in the nas?
- Condor101Sep 23, 2015Aspirant
Hi,
Thanks for the quick replies.
Looking at the guide it is definately a NV+ V1 as the 3 pin power is in the bottom left of the rear panel.
I bought the unit 25 February 2010 from Amazon
Backup wise I have an external 100gb drive that does a weekly backup but I think that only backs up the mydocuments directory as I couldn't backup the full 8tb.
I haven't tried factory resetting as I don't want to lose any data yet.
The USB image using rw32 to burn a file called ReadyNAS_USB_Flash_Recovery-4.1.12.img to a flash drive and then boot for 20s just passed the fourth set of lights, but I dont even get that, just the 5 then 3 blinking sequence.
Stephen:
Did you try reinserting all disks except for disk 1, and seeing if it boots? (Hopefully the disks are labeled by slot).
Yup have tried but same 5 then 3 blinking seq
I have recorded the flashes on my mobile phone and uploaded to youtube if it helps:
cheers
Daniel
- vandermerweSep 23, 2015Master
Do you have a spare disk?
I think you must attempt to factory default the nas with a spare disk. If the unit does not factory default with a spare disk then someone will have to look in tech support mode, or you will need to do the USB boot. The disk you have in the unit must be known to be good, and of course not from your array.
I have a couple of 1.5tb spare hard disks so will give that a go.
Presume factory reset is hold reset button in, on back of unit, with paperclip for greater than 30secs , if I recall?
Will sleep on it for tonight and try tomorrow after work....
cheers guys will get back to you tomorrow.
ta Daniel
