Condor101
Sep 23, 2015Aspirant
NV+ will not boot - LED flashes
Hi All, Does anyone know what the following LED state means: Green LED against drive 1 blinks 5 times. Then all 5 green LEDs (drive 1 to 4 and act) and the blue power button blinks 3 times qu...
- Sep 23, 2015
Also have a read through this. The led pattern is similar.
https://community.netgear.com/t5/Using-your-ReadyNAS/NV-will-not-boot-LED-flashes/td-p/925981
Although the led pattern is not typical of a memory problem, the user in that post made progress by changing the memory. Worth trying to do a memory test too if the unit lets you.
Factory default:
Condor101
I have a couple of 1.5tb spare hard disks so will give that a go.
Presume factory reset is hold reset button in, on back of unit, with paperclip for greater than 30secs , if I recall?
Will sleep on it for tonight and try tomorrow after work....
cheers guys will get back to you tomorrow.
ta Daniel
vandermerwe
Sep 23, 2015Master
Factory default:
