markg1
Mar 27, 2014Aspirant
NV+ wont power up
I have NV+ that is about 6.5 years old, and has been running pretty much continuously since purchase. We recently went on a 2 week vacation, so I turned everything off including the NV+. Now it w...
markg1
Mar 28, 2014Aspirant
StephenB wrote: Check this post: viewtopic.php?t=10259
If the NAS serial number is within the specified range, then you are entitled to a new power supply from netgear, even if you are out of warranty.
outside that range, unfortunately, but thanks for the tip!
