bertschj's avatar
bertschj
ReadyNAS NV+ Won't Power Up
Hello -
My NV+ will not power up.  PS not smoked - just no power.  Reseated RAM also - no change.  Saw several threads regarding defective PS - my serial falls within range - 000D-A201-837E.  Called Netgear and they said no longer replacing.
Case- 28843310 if that helps.
Couple things:
1- is that correct?  Saw thread from a few months ago and they replaced then.
2 - If no more replacements, is it possible to use PS from NV+/RND4410v3 unit?  I've purchased a new RN214, but need this up so I can transfer.
If neither possible, any other ideas besides purchasing PS from Amazon?
Thanks
  • Hello bertschj,
    I'm sorry but this unit is very old that Netgear no longer manufactures even its PSU.
    You might be able to find a someone who sells ReadyNAs NV+v1 power supply on the Internet. The part number is RND4PSU1-10000S.
    Welcome to the community!
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello bertschj,
    • bertschj's avatar
      bertschj
      Thanks Jenn
      Is this possible?
      "is it possible to use PS from NV+/RND4410v3 unit? "
      • JennC's avatar
        JennC
        Hello bertschj,
        RND4410v3 is probably a Sparc-based NAS too. Can you PM me the SN? I will try to check if I can identify if it is Sparc-based which is the same as the v1.
ProSupport for Business
