avpman1
Apr 20, 2014Aspirant
NVX Business Edition total Max HDD Capacity?
I have an NVX Business Edition with four 2TB drives in it. I want to replace all of them with 3TB or 4TB drives. Will the NVX handle the 12TB or 16TB capacity and if so can I expand the array the usu...
Apr 20, 2014Guru - Experienced User
The NVX will handle 4 TB drives.
It will not expand volumes more than 16 TiB. And there is a growth limit of 8 TiB over the life of the volume. So to answer your question we need to know the disk configuration you used at your original install (or last factory reset).
If you can't expand you current volume, you'll need to do a factory reset with the new drives in place. Given the 16 TiB limit, you might consider switching to flexraid, as it would give you more expansion options later on (as the 5 and 6 TB drives come onto the market).
