ahpsi1
Jan 31, 2013Tutor
NVX, share content missing after vol chk, case 20484647
Just filed the issue with NTGR and figured I'd best start documenting now. System was running and data was accessible however there appeared to be a permissions error on a share I could not correct...
mdgm-ntgr
Feb 01, 2013NETGEAR Employee Retired
A factory reset is a drastic step to take as it wipes the disks of all data. If you do so though you would get a clean setup on the firmware you are running and filesystem improvements that can only be obtained via a factory default. Since 4.2.12 the NVX has had native EXT4 with huge file support (requires factory reset if upgrading from previous firmware).
