ahpsi1
Jan 31, 2013Tutor
NVX, share content missing after vol chk, case 20484647
Just filed the issue with NTGR and figured I'd best start documenting now. System was running and data was accessible however there appeared to be a permissions error on a share I could not correct...
JohnnyB11
Feb 01, 2013Aspirant
Yes. I know.
However, even after the factory default, expansion does not work properly! After factory default with 2x2TB and 2x1TB drives installed and resyncing the initially automatically created 3TB volume, online expansion to 4TB took place, and resyncing again (~10h in total). I rebooted and, then, again but with the manual file system check: There are plenty of errors while there are only 60 files. Some sound very promising like "Inode x has compression flag set on filesystem without compression support."
There are no SMART errors and the drives are IMHO on the HCL: 2xWD20EFRX and 2xWD1002FBYS.
