ahpsi1
Jan 31, 2013Tutor
NVX, share content missing after vol chk, case 20484647
Just filed the issue with NTGR and figured I'd best start documenting now.
System was running and data was accessible however there appeared to be a permissions error on a share I could not correct through Frontview. I thought I'd best work with known sane filesystem so I (stupidly) thought running a FSCK (through Frontview) would be a good place to start. My bad. Rebooted the NVX BE and selected 'Perform volume scan on next boot". After the unit came back up all data in each share appears missing. Volume still shows a non-trivial percentage in use. Logging in with SSH I see the shares but nothing in them. No add-ons in use, only Bonnie installed. Only CIFS, HTTP and RSYNC enabled.
I'm a little worried as this issue (or one that seems somewhat similar) has been seen on the forum before:
http://www.readynas.com/forum/viewtopic.php?f=20&t=68890&p=384524
http://www.readynas.com/forum/viewtopic.php?f=50&t=69247&p=384290
http://www.readynas.com/forum/viewtopic.php?f=20&t=67688&p=379780
http://www.readynas.com/forum/viewtopic.php?f=50&t=67051&p=375481
It appears in some cases the volume can be accessed after being mounted read-only (though I believe mine is already mounted) and in others repair to the volume was enough - while some found their data gone for good. In any case - suggestions?
- horshackAspirantYeah, my NVX is completely functional and clean. I built/expanded completely on 4.2.19 and then upgraded to 4.2.22. In 4.2.22 everything is still working and clean (RAID Scrub, Online FSCK, etc...)
- LeiaNETGEAR Employee RetiredHi guys, we upgrade the ext2/ext3/ext4 file system utilities - e2fsprogs in 4.2.23 T build, so it's fixed now. Please do not expand volume in 4.2.22. Just wait 4.2.23.
And the bug is only in NVX, 32 bits system. Ultra & Pro serials, 64 bits system have no problem.
Thanks.
-Leia - ahpsi1TutorNice!
You have my gratitude for addressing this issue. :thumbsup:
