Trumble
Jan 14, 2012Aspirant
Odd disk usage question
Hi To all! I have only had my ReadyNAs Duo V1 for a month now so in all probability i am probably doing something wrong - but here goes... Unit has on 2TB drive and has been factory reset to run...
mdgm-ntgr
Jan 14, 2012NETGEAR Employee Retired
2000000 MB = (2000000 / 1024 / 1024) TB which is a bit under 1.91TB
Could you try a reboot under System > Shutdown with a quota check?
What version of RAIDiator are you running?
Welcome to the forum!
