Trumble
Jan 14, 2012Aspirant
Odd disk usage question
Hi To all! I have only had my ReadyNAs Duo V1 for a month now so in all probability i am probably doing something wrong - but here goes... Unit has on 2TB drive and has been factory reset to run...
mdgm-ntgr
Jan 14, 2012NETGEAR Employee Retired
You do realise that you don't have to restrict the user to a quota like that. Without a quota, the user will be limited simply in that they can't add more data than free space on the volume. Setting the quota to 0 is effectively an "unlimited" quota.
Try the reboot with quota check and report if you still have a problem.
