Trumble
Jan 14, 2012Aspirant
Odd disk usage question
Hi To all! I have only had my ReadyNAs Duo V1 for a month now so in all probability i am probably doing something wrong - but here goes... Unit has on 2TB drive and has been factory reset to run...
mdgm-ntgr
Jan 15, 2012NETGEAR Employee Retired
What brand and model disks?
What version of RAIDiator?
How is your Windows machine connected to the NAS? Via ethernet? Does your router/switch have gigabit ethernet? Are you using Cat5e or newer ethernet cables?
If you download your logs (Status > Logs > Download all logs) and extract the zip contents what does partition.log look like?
