Trumble
Jan 14, 2012Aspirant
Odd disk usage question
Hi To all! I have only had my ReadyNAs Duo V1 for a month now so in all probability i am probably doing something wrong - but here goes... Unit has on 2TB drive and has been factory reset to run...
Trumble
Jan 15, 2012Aspirant
2 x Samsung 2TB HD204UI - no particularly fast but i think should go faster than that !
RAIDiator 4.1.8 [1.00a043]
NAS is connected directly into a netgear FS116 - 16 port 10/100 switch - no gigabit
PC is connected into the same switch via a patch panel - i have structured cabling in the house (port on wall behind PC, port to patch panel etc) cables are all Cat5e sorry no gigabit.
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md3 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md2 doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 5144607 524288 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary.
/dev/hdc3 5144608 3907010591 1950932992 fd Linux raid autodetect
Disk /dev/hde: 2000.3 GB, 2000398934016 bytes
/dev/hde1 32 4096031 2048000 fd Linux raid autodetect
/dev/hde2 4096032 5144607 524288 fd Linux raid autodetect
/dev/hde3 5144608 3907010591 1950932992 fd Linux raid autodetect
Note: sector size is 1024 (not 512)
Disk /dev/md0: 2097 MB, 2097086464 bytes
2 heads, 4 sectors/track, 255992 cylinders, total 2047936 sectors
Units = sectors of 1 * 1024 = 1024 bytes
Disk /dev/md3: 1997.7 GB, 1997755318272 bytes
2 heads, 4 sectors/track, 243866616 cylinders, total 1950932928 sectors
Disk /dev/md1: 536 MB, 536805376 bytes
2 heads, 4 sectors/track, 65528 cylinders, total 524224 sectors
Disk /dev/md2: 1997.7 GB, 1997755318272 bytes
