Trumble
Jan 14, 2012Aspirant
Odd disk usage question
Hi To all! I have only had my ReadyNAs Duo V1 for a month now so in all probability i am probably doing something wrong - but here goes... Unit has on 2TB drive and has been factory reset to run...
mdgm-ntgr
Jan 15, 2012NETGEAR Employee Retired
Same speed for both volumes?
Can you try a direct-connection: How to Direct Connect to your ReadyNAS
Also note there are some performance issues with 4.1.8
There is a new beta: http://www.readynas.com/forum/viewtopic.php?f=17&t=59222
