Trumble
Jan 14, 2012Aspirant
Odd disk usage question
Hi To all! I have only had my ReadyNAs Duo V1 for a month now so in all probability i am probably doing something wrong - but here goes... Unit has on 2TB drive and has been factory reset to run...
Trumble
Jan 16, 2012Aspirant
Wow - now thats really interesting i am suprised you can do that.
Either way, followed all those instructions, connecting the NAS directly to the port on my patch panel which is connected to PC gives a transfer rate of 13.5Mbs (as reported by Windows). Phew - I'm not sure i would expect any more than that - is that reasonable ?
I havent tried the beta software yet - will give that a go later and report back.
Thanks
T.
Thanks
T.
