Trumble
Jan 14, 2012Aspirant
Odd disk usage question
Hi To all! I have only had my ReadyNAs Duo V1 for a month now so in all probability i am probably doing something wrong - but here goes... Unit has on 2TB drive and has been factory reset to run...
Jan 17, 2012Guru - Experienced User
The read speed is about all you can expect with a 100 mbit switch. Clearly something else is slowing down the writes a bit. RAID writes are slower than reads (since the reads can potentially be spread across the two drives, but the writes need to be done on both). The performance issues in 4.1.8 certainly won't help.
Trumble wrote: Ftp read from NAS through the switch
ftp: 4676780032 bytes received in 440.11Seconds 10626.41Kbytes/sec.
Ftp write to NAS through the switch
ftp: 4681418752 bytes sent in 633.28Seconds 7392.28Kbytes/sec.
