Anonymous
Jun 20, 2014Old Snapshot Deletion Errors
I was removing several old auto-snapshots from a RN316 OS6, and unfortunately something went wrong and the NAS went into a constant reboot/reset sequence. I rebooted in safe mode, scan disk'ed, etc. a...
ReadySECURE
Jun 20, 2014Apprentice
Do you have Allow Snapshot Access enabled on that share? If so, turn it off prior to attempting deletion.
If you are in SSH, you can run the mount command to see all your mounts; if you have snapshot access enabled, then you'd need to turn it off as the snapshot is literally in use.
