Retired_Member
Jun 20, 2014Old Snapshot Deletion Errors
I was removing several old auto-snapshots from a RN316 OS6, and unfortunately something went wrong and the NAS went into a constant reboot/reset sequence. I rebooted in safe mode, scan disk'ed, etc. a...
Retired_Member
Jun 20, 2014@vandermerwe yep, its the latest OS6.1.8.
@ readysecure1985 good call, I turned off snapshot on the shares and it deleted from TImeLine. Thanks! :)
Seems the ._share folder is the only valid data folder, the others look like symbolic links. Once snapshot is disabled, the only folder containing the snapshot files is ._share (phew)
