Retired_Member
Jun 20, 2014Old Snapshot Deletion Errors
I was removing several old auto-snapshots from a RN316 OS6, and unfortunately something went wrong and the NAS went into a constant reboot/reset sequence. I rebooted in safe mode, scan disk'ed, etc. a...
Jun 23, 2014Guru - Experienced User
Perhaps contact support.
ernst stucki wrote: I run a ReadyNas 102 v2 with 6.1.8 and have similar problems with snapshots as far I know on one share called Backup. Neither is it possible to delete snapshots nor to delete the share. I already scrubbed the volume two times and restarted the system each time. The behavior did vary after those operations. when I try to delete the share from the web interface the system "turns" for a while but after that - without any message - the share is still shown and can be browsed. When I try to delete snapshots I get the message "Ordnervorgang fehlgeschlagen. Code 1004030000. Also switching off continuous protection and snapshot access permission didn't help. I suppose that it has to do with a corrupt btrfs file system.
Does someone know a way to get rid of that share ( I have copied all data to an other share and also on an ubs disk) without reset and rebuild the whole nas? Is it possible and would it help to make a btrfs diskcheck somehow? (As mentioned Scrubbing didn't help.)
