Retired_Member
Jun 20, 2014Old Snapshot Deletion Errors
I was removing several old auto-snapshots from a RN316 OS6, and unfortunately something went wrong and the NAS went into a constant reboot/reset sequence. I rebooted in safe mode, scan disk'ed, etc. a...
nasischijf
Oct 05, 2014Aspirant
mdgm wrote: That won't remove the entries for the snapshots from the readynasd database though, so in the GUI you would probably still see references to those snapshots.
True, but at least it gives you valuable space back. Would it be possible that the defrag command from Frontview > Volumes > Data has screwed with the snapshots?
Would the snapshots entries be fixed after a reinstall, say when a new firmware arrives?
