powellandy1
Dec 02, 2020Virtuoso
Onedrive Backup Failure
Hi Struggling to get Onedrive backup set up (upload only). RN422 with 6.10.3. Set it up a couple of times (as pictured below) Repeatedly fails. Log shows: Dec 02 21:29:29 Backup ng-c...
- Dec 10, 2020
The dot (little "light") in the icon turns blue when the NAS is backing up the files.
Could you please follow this https://kb.netgear.com/25625/How-do-I-send-ReadyNAS-system-logs-to-NETGEAR-Support to download the system logs and then send it to me in a private message?
B_L
Dec 06, 2020NETGEAR Expert
We released ReadyNAS 6.10.4.
https://kb.netgear.com/000062588/ReadyNAS-OS-6-Software-Version-6-10-4
Please upgrade your NAS and check if it fixed your OneDrive backup issue.
powellandy1
Dec 06, 2020Virtuoso
Same issue.
-- Reboot -- Dec 06 16:03:59 Backup systemd[1]: Started One Drive Service client for ReadyNAS. Dec 06 16:03:59 Backup ng-csd[5578]: Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings Dec 06 16:03:59 Backup ng-csd[5578]: W1206 16:03:59.139441 5578 FSCache.cpp:78] Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings Dec 06 16:04:23 Backup systemd[1]: Stopping One Drive Service client for ReadyNAS... Dec 06 16:04:23 Backup systemd[1]: Stopped One Drive Service client for ReadyNAS. Dec 06 16:04:24 Backup systemd[1]: Started One Drive Service client for ReadyNAS. Dec 06 16:04:24 Backup ng-csd[5697]: Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings Dec 06 16:04:24 Backup ng-csd[5697]: W1206 16:04:24.851426 5697 FSCache.cpp:78] Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings
After upgrade to 6.10.4 and reboot Onedrive was off, so entered all details again and still not working. Dot is blue. No new files appear to have been copied.
