JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
BrianL2
Dec 02, 2015NETGEAR Employee Retired
Hi JimG1,
Welcome to the community!
I haven't experienced this problem after updating the device Firmware to 6.4.1. Did you check if there's a service or maintenance ongoing while you are navigating the files? Was the same behavior experienced after rebooting the device or shutting it down completely?
I look forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
