JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
ntnsvh
Dec 02, 2015Guide
Hi Everyone,
I, too, have this problem. File access on the local network is just too slow. I have already rebooted the RN102 to check if it would help but to no avail. The difference between 6.4.0 and 6.4.1 on local network file access is very significant.
Does anyone have a solution to this aside from downgrading to 6.4.0?
Thanks,
mdgm-ntgr
Dec 02, 2015NETGEAR Employee Retired
Hi ntnsvh,
If the FAQ did not resolve the problem you are facing either, can you open a support case and let us know the case number?
If it is an online case please attach the logs zip file to it.
- DBODec 02, 2015Tutor
I'm getting exact same issue. Upgraded yesterday and local network file speed has gone to the dogs. Long time-out errors on accessing any SMB enabled shares from Windows 10 clients. Essentially unworkable. Tried rebooting etc to no avail. Web based access via admin console in browswer seems to be at regular speeds but the rest is broken.
Is there any way we can roll back to previous firmware?
- mdgm-ntgrDec 02, 2015NETGEAR Employee Retired
Which firmware did you update from?
Can you send in your logs (see the Sending Logs link in my sig)?
We upgraded from 6.4.0
I've extracted and sent the log file zip.
Thanks for your help.
- JimG1Dec 03, 2015Guide
Yes DBO, I had to learn how to do this yesterday to recover (downgrading 6.4.1 to 6.4.0). Follow this - its pretty easy luckily ...
http://kb.netgear.com/app/answers/detail/a_id/22804
- Vati42Dec 03, 2015Aspirant
It worked!! With 6.4.0 everything is fine again.
Thanks a lot.
