JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
BrianL2
Dec 02, 2015NETGEAR Employee Retired
Hi JimG1,
Welcome to the community!
I haven't experienced this problem after updating the device Firmware to 6.4.1. Did you check if there's a service or maintenance ongoing while you are navigating the files? Was the same behavior experienced after rebooting the device or shutting it down completely?
I look forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
JimG1
Dec 03, 2015Guide
Yes, Brian, there was nothing unusual going on. We fully shutdown the NAS once and tried restarting several clients before falling back to 6.4.0. This immediately fixed the speed issue (but brought back the old bugs of course).
I'll wait for 6.4.2 before I try again. Meanwhile in 6.4.0 I can't get to the admin window (just the splash screen) after a backup runs (or perhaps its some other internal operation). But this has always been the case for us with 6.4.0 and several earlier releases.
- connor25Dec 04, 2015Tutor
JimG1 interesting, I have had same issue with the splash screen and using it remotely its a real pain, I hadn't known it was the backup causing this, but this now makes sense!
I also found changing the backup to NTFS it did it without errors whilst with fat32 had errors and had to restart a few times.- JimG1Dec 04, 2015Guide
I've never been able to figure out exactly what makes the NAS stop responding on the admin console, but it seemed be in this state most morning after a backup. Only power cycling seemed to free it.
Interesting that the drive format may be involved.
We switch to this NAS last year for ease of drive maintenance (swapping out drives in the RAID array) but I have to say, the effort we've put into keeping this thing working and keeping backups reliable has far outstripped the effort of maintaining the drives embedded in our servers.
if its any help, it was a samsung drive... I also noticed even though the drive was new and formated FAT32 it looked like two drives on the admin panel which concerned me a bit, I am not sure why it did this and don't have a reason either.
I was also only running the inbuilt virus, but I have been told this could be the problem from another user... so have turned off for now, although hope the desktop anti-virus will be enough.
