JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
bwwestbrook
Dec 04, 2015Aspirant
I too am having the exact same issues. I upgraded the firmware to 6.4.1 and now it takes several minutes to open or save a simple file. I am also getting read only errors when trying to reopen files.
I will try downgrading. Please fix Netgear.
- connor25Dec 04, 2015Tutor
Try disabling the anti virus, and see if this is the problem?
downgrading worked fine for me, works like a dream now apart from the original issues!
