JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
Bob_K
Dec 08, 2015Tutor
I have a ReadyNAS Ultra 4 running OS 6.4.1. I know you guys don't approve of or support using OS6 software on the old systems; however, I wanted to let you know that turning off Anti-Virus also instantly fixed my unusably slow performance problem.
