JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
pet2tso
Dec 13, 2015Aspirant
Thanks to StepenB!! I have downgraded to FirmWare 6.4.0, and things are back to normal. I learn a few hard lessons from Netgear. This is not the first time the system go to pots after firmware upgrade. I will be very carefull from this point on.
