JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
gsvenningsen
Dec 15, 2015Tutor
I've also experienced the same problems as described here after I upgraded to firmware 6.4.1. Shared files/folders were very slow over local network. I have only two "apps" installed: Anti-Virus plus and bit torent sync.
The problem dissappeared when the data-folder(s) was excluded from the Anti-virus "live scan". It is still slow on folders that have Live-Scan enabeld.
As a (possible) workaround I've scheduled full anti-virus scan at night when the NAS is not in use.
