JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
Bob_K
Dec 15, 2015Tutor
I can also confirm other reports of slow transfer speeds even with AntiVirus disabled. Using Goodsync, I previously saw nearly 100MB/s transfer rates on backups (using jumbo frames) on prior firmware versions. After upgrading the firmware to OS 6.4.1, I get averages between 15 MB/s and 40 MB/s.
Roel1
Dec 18, 2015Apprentice
My ReadyNAS 102 has also slowed down so much it is not really usable. I will see if disabling the AV helps, as other posts suggest, and failing that, I will revert to 6.4.0.
10 mins later - Disabling the AV did the trick and it is now running at its normal speed.
