JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
AdriFrijters
Dec 29, 2015Tutor
Yes sir.
is there a manual how to downgrade?
adri.
stephen_neph
Dec 29, 2015Initiate
As a (previously) satisfied ReadyNAS user who has wasted several hours waiting for "hanging" files after an upgrade 6.4.0 to 6.4.1 last night on NAS 401, thankyou to those who contributed to this thread and the helpful instructions. Downgrade back to 6.4.0 fixed the problem -- comments about using 6.4.1 and disabling the AV noted, but a functional solution is the key for me.
- mdgm-ntgrDec 29, 2015NETGEAR Employee Retired
6.4.2 Beta 1 is available which is another option. This has some bug fixes in it and we would appreciate feedback on this release in the beta forum.
- iscgdaveDec 29, 2015Aspirant
I've been researching this for a client but their issues also started after upgrading to firmware 6.4.1 on RN 3130
The Antivirus is already disabled so I will try the Beta firmware.
Strike that, I found the firmware
- Roel1Jan 05, 2016Apprentice
I'm not keen on trying out beta releases, so will wait for the official release.
- BrianL2Jan 05, 2016NETGEAR Employee Retired
Hi Roel1,
There's no ETA when the new Firmware will be released. Check the community and our support website for updates.
Kind regards,
BrianL
NETGEAR Community Team
