JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
AdriFrijters
Jan 04, 2016Tutor
Dear all, specially the guys from Netgear.
See us struggeling and fighting with data transfer, Reading all this, you should cry out loud. Why, did we not pay the hardware in time? Did we ask for an os update with problems? No, I certainly not, who did? Please speak.
How long does it take to clean up the mess an apologize?
Please tell me also how to set the virus scanner correct.
Greetings from The Netherlands, Adri, just a simple user.
Jan 04, 2016Guru - Experienced User
I'm not from Netgear...
To disable the Antivirus service, you log into the web admin page. That will put you on the systems page. Select "settings". Antivirus shows up under "services", and you click on it to enable/disable it.
- AdriFrijtersJan 06, 2016Tutor
dear member of the forum,
this does not work.
i can just uninstal or instal the virusscanner.
greets, Adri.
- StephenBJan 07, 2016Guru - Experienced User
this does not work.
greets, Adri.
You are confused, since the antivirus scanner is built-in and cannot be uninstalled. I suspect you are confusing the "Anti-Virus Plus" control app with the scanner.
Log into the web UI and go to this screen:
Any service with a green stripe across it is enabled. You will see that antivirus is disabled on my system. If you click on it, you'll see an option to enable/disable it.
