JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
AdriFrijters
Jan 07, 2016Tutor
Stephen, thnx.
The app is of no use i gess.
Just de-instal it to make it all clear.
Thanks for the answer.
- StephenBJan 07, 2016Guru - Experienced User
AdriFrijters wrote:
The app is of no use i gess.The app gives you the ability to set options (e.g. what to do if viruses are found, etc).
- AdriFrijtersJan 07, 2016Tutor
stephan,
this is on the screen in the viruspage
Is that normal?
why the red and yellow dots?
thanks
Adri.
Red is reinforcing that the live scan is disabled.
Yellow is likewise reinforcing that scheduled scans are disabled.
Netgear is treating no live scan as a "red" (critical) condition, and no scheduled scan as a "yellow" (not so critical) condition.
Of course how critical they really are depends on the rest of your set up. All the files on my NAS come from one of my PCs, which all have their own antivirus software running.
