JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
AdriFrijters
Jan 14, 2016Tutor
The fix is roll out an update that's actually a downgrade to 6.4.0 and you give yourself a nice way out.
We are fooled but happy an inward of the trick.
Jan 14, 2016Guru - Experienced User
6.4.0 had other problems that were fixed in 6.4.1 (or 6.4.2 beta) - and many users need those fixes. So the downgrade to 6.4.0 works for some, but it is not an option that works for everyone.
Turning off AV isn't the best, but it isn't the worst either.
