JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
kylefarris
Jan 14, 2016Aspirant
I have htop installed on my NAS so I took a screenshot of the output which absolutely verifies without a doubt that the culprit is the ctscan daemon (the antivirus server). Their instances are pegging my NAS's CPU cores at 100%.
