JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
Jan 22, 2016Guru - Experienced User
Eeuwe wrote:
Now I disabled the antivirus and the problem seems to be over.
But..
How risky is to wordk without antivirus?
My computers have Norton antivirus
If you run both scanners, then of course there is a chance that the NAS AV will find something that Norton misses. In my opinion that chance is pretty small.
If you are downloading files directly to the NAS with an App (for instance, executable torrent files), then AV on the NAS will run right away, while Norton would likely run later.
I also have Norton on our PCs, and I've always left AntiVirus disabled on the NAS.
sandisn
Jan 31, 2016Aspirant
I disabled 6.4.1's Antivirus and that worked for me; will keep an eye on this forum to know when the fix from NetGear is ready. Thank you to Stephen for all the clear, helpful info you have posted on this subject as well as the positive attitude!
- stevecr25Feb 01, 2016Aspirant
Having the same slowdown issue on my 3130 with 6.4.1.... Turned off the antivirus service and the system came right back to life.
Will wait for the next firmware update instead of downgrading to 6.4.0.
Thanks for the troubleshooting help!
-Steve
