JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
AdriFrijters
Feb 09, 2016Tutor
I heard / read 6.4.2 is available. Is This correct and is it safe?
- StephenBFeb 09, 2016Guru - Experienced User
AdriFrijters wrote:
I heard / read 6.4.2 is available. Is This correct and is it safe?It is released, and I've installed on my RN102 and my RN202. No problems so far.
BTW, I did a factory reset on the RN102, and that restored its original performance (in fact write speeds are quite a bit faster than I measured back in the 6.2.x days). I'm seeing 70-75 MB/s on the RN102 (both read and write), and ~100 MB/sec on the RN202.
Both are jbod, not RAID-1.
