JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
AdriFrijters
Feb 09, 2016Tutor
Thnx. For a NAS in use no option (i think). Thanks.
Feb 09, 2016Guru - Experienced User
There is some down time.
Restoring the data with rsync took 1 TB per day. I think if you used NFS or CIFS it would have been > 4 TB per day.
- amtrakuk1Feb 09, 2016Aspirant6.4.2 update NOT RECOMMENDED for RN104 - AV issue still exists on mine even after reboot.
- BrianL2Feb 09, 2016NETGEAR Employee Retired
Hi amtrakuk1,
There are bugs and issues that were addressed by the Official 6.4.2 Firmware. We highly suggest that we keep are units up to date. With regard to the AV issue, we don't have a fix available at the moment.
Kind regards,
BrianL
NETGEAR Community Team - SkepherFeb 09, 2016Aspirant
Not looking good on the RN 516 either. Installed 6.4.2 update and turned virus checker on again - SLOW again... real SLOW, like the subject says to the point of unusable. Turned off virus checker and all well again.
Please resolve.
