JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
Peter_the_Hat
Mar 03, 2016Aspirant
What is the latest on this ? its been about 3 months now without a solution.
Peter
JennC
Mar 03, 2016NETGEAR Employee Retired
Hello Peter_the_Hat,
Can you try creating a test user and see if you get the same problem. Use the web portal first and not the desktop client or app. Web portal should work first.
- mdgm-ntgrMar 10, 2016NETGEAR Employee Retired
Looking to do some isolation testing with a few users of 100 series or RN2120 systems who have slower performance with anti-virus disabled than they had in 6.2.4. Please PM me if interested.
- PhilGregory31Mar 14, 2016Aspirant
ReadyNas 104 very slow with 6.4.1 and 6.4.2 installed.
Menu's almost un-usable , operations such as backup not completing and stuck in-progress.
Antivirus disabled makes no difference.
Went back down to 6.4.0 as advised by this thread.
All working normally again.
