JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
mdgm-ntgr
Mar 18, 2016NETGEAR Employee Retired
There is a fix in ReadyNASOS 6.5.0-T338 (Beta 2) for the anti-virus issue as well as some other fixes. Please try it.
Hunt_trex
Mar 23, 2016Aspirant
The update fixed the issue. Gee thanks Netgear for all the frustration and wasting my time trying to troubleshoot an issue the should never have happened. This is very frustrating and made me question if I will purchase a netgear product in the future.
Once again thinks for wasting my time.
- mdgm-ntgrMar 23, 2016NETGEAR Employee Retired
- sandisnApr 03, 2016Aspirant
Thanks for the hotfix! Works great on my RN10400.
- mdgm-ntgrApr 03, 2016NETGEAR Employee Retired
Thanks for your feedback. I'm going to close this thread now.
If you have performance issues that are unrelated to anti-virus and are still running 6.4.x please post about these in a separate thread.
If you have problems installing the hot-fix please post about those in a separate thread.If you still have issues on 6.5.0 Beta please post in the beta forum.
