JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (th...
- Mar 23, 2016
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
amtrakuk1
Mar 29, 2016Aspirant
Installed 6.5.0-T338 (B2) and enabled the AV. All seems rine on my 104
fkhan
Mar 31, 2016Aspirant
issue seems to be fixed now
thanks RN team.
- AdriFrijtersApr 03, 2016Tutor
is the new OS 6.5 out of the Beta stadium and also working on the 100 serie?
Who has the experience?
- dsnpevlApr 03, 2016Virtuoso
AdriFrijters wrote:is the new OS 6.5 out of the Beta stadium and also working on the 100 serie?
Think it's still in beta. I am testing 6.5.0-T338 on RN516 and RN312. Backup speed to NTFS USB 3 drive is still very low for me (12 MB/s), even with AV switched off. Netgear is looking into the issue. One improvement I can see is that the Admin GUI no longer hangs when doing a large backup to USB.
- StephenBApr 03, 2016Guru - Experienced User
Yes, and there are two threads already open in the beta forum on USB performance.
FWIW, with 6.5.0-Beta-1 I measured 24 MB/sec for a USB3 NTFS backup of a music folder on my RN102.
