vaprasad
Jun 09, 2017Aspirant
OS 6.7.4 what happened to ldconfig?
attempting an ldconfig results in: root@mydevice:/# ldconfig
/sbin/ldconfig.real: /usr/lib/libreadycloud.so.1 is not a symbolic link attempting to reinstall libc6 shows it's a Netgear proprietary v...
Jun 11, 2017Guru - Experienced User
vaprasad wrote:
Other than possibly breaking Readycloud, are there any risks associated with installing standard jessie libc6? I don't mind losing ReadyCloud as I don't use it.
You risk breaking Readynasd - the NAS application behind the Web UI.
mdgm-ntgr
Jun 12, 2017NETGEAR Employee Retired
You could run the OS6 VM and compare with what you see in that and try to debug what's gone wrong on your system. Sounds like there's a file where there should be a symlink or something like that.
