schecter948
Nov 03, 2017Aspirant
OS Reinstall/Factory reset not working
Hello Community , I´ve trouble with my RNDX4420 , because i have no access to the webpage. It appears in Raidar and match the ip address in my network. Also i can ping it with my computer. Now, ...
- Nov 03, 2017
schecter948 wrote:
Probably it´s the old firmware that can´t handle larger space than 2tb.
Yes.
Note some of the rackmount chassis can't handle > 2 TB disks in every slot (a hardware limitation). But that's not an issue with the RN4200v2. So you should upgrade the firmware - that will let you use the larger disks.
Sandshark
Nov 03, 2017Sensei
And since you've already done a factory default, now would be the time to consider moving to OS6 on your 4200V2. It's not officially supported by Netgear, but it works and aleviates several problems related to the old Debian distro OS 4.2.x is based on.
mdgm-ntgr
Nov 03, 2017NETGEAR Employee Retired
The RNDX4420 is a desktop 4-bay ReadyNAS, the NVX that shipped with 4x2TB disks.
The NVX can’t run OS6 as it has a 32-bit CPU.
