thecleartech
Dec 13, 2018Aspirant
OS6 on ReadyNAS Pro 4 (RNDP4000)
Is OS6 supported on legacy ReadyNAS models, specifically the RNDP4000? The NAS in question currently runs RAIDiator 4.2.31 ... but the lack of support for SMB2 (SMB1 appears to be the only SMB protoc...
thecleartech
Thanks - if you're able to dig up the checklist you'd used to effect that upgrade to OS6, that'd be much appreciated!
TeknoJnky
Dec 13, 2018Hero
well more important than the checklist, would be a copy of the modified firmware file(s) that will allow upgrade/conversion to os6.
I don't know if I have those around any more, but I'll look.
Hopefully someone else can help as well.
in the mean time, you may want to review the links @ https://www.google.com/search?&q=readynas+os4+to+os6
- StephenBDec 13, 2018Guru - Experienced User
Instructions with working download links are here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Lost-contact-with-NAS-after-upgrading-Windows-10/m-p/1656875#M150811
- thecleartechDec 14, 2018Aspirant
<deleted, wrong thread>
- jjcf89_2Dec 16, 2018Tutor
I just followed the instructions posted here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUPPORT/m-p/897023/highlight/true#M50465
to upgrade my ReadyNAS Ultra 6. So far no issues.
