prometheus1
Nov 03, 2014Aspirant
os6 on ultra 4
ok so i have been holding back until all the bugs have been ironed out, who is running it on on one of these :D and what should i look out for during the upgrade
mdgm-ntgr
Nov 23, 2014NETGEAR Employee Retired
Well that depends on various factors including how you configure the unit, what apps you install, what apps and services you run etc.
If you try OS6 I would suggest running 6.2 once that is available.
You can go back to OS4 if you don't like OS6 though the downgrade also requires a factory default (wipes all data, settings, everything).
