prometheus1
Nov 03, 2014Aspirant
os6 on ultra 4
ok so i have been holding back until all the bugs have been ironed out, who is running it on on one of these :D and what should i look out for during the upgrade
dhonzik
Nov 25, 2014Aspirant
I have a Ultra 4 Plus and will be taking the big jump this holiday weekend since I found a 3TB drive to store the backup on. I am currently on 4.2.27 firmware. Do I need to downgrade back down to 4.2.26?
My understanding these are the steps
1. BACKUP, BACKUP, BACKUP
2. Download 6.0.X package from NTGR
3. Edit the latest IMG for instalation by 4.2 Frontview
3. Install via 4.2.x menu
4. Reboot
5. Factory Default the system
I plan on using the modified image R4toR6_latest.bin with Prep4ToR6_0.1-x86.bin for step 3 (I install the prep then R4toR6 without rebooting in between installing the bin file. Is this correct?)
My question can I use the new 6.2 image in step 3 or do I need to modified it or upgrade to 6.2 once in install R4toR6_latest.bin image
4. Reboot
