prometheus1
Nov 03, 2014Aspirant
os6 on ultra 4
ok so i have been holding back until all the bugs have been ironed out, who is running it on on one of these :D and what should i look out for during the upgrade
mdgm-ntgr
Nov 25, 2014NETGEAR Employee Retired
Install the prep add-on then the R4 to R6 latest image. If you downloaded that since the global announcement on 6.2 was made then it would be one that will update you direct to 6.2
You can go direct from 4.2.27 to 6.2.0
If you install the prep add-on it should do a factory default automatically at the appropriate point in the upgrade process.
